Offset
Geometry > Face > Offset
Dialog Box
Offsets selected faces by a specified distance.
Offset Distance
Positive values create an offset in the face normal direction; negative values create an offset in the opposite direction.
Duplicate and offset
If this toggle is on, it creates new faces for the offset. Otherwise the selected faces itself gets offset.
  • Move boundary along neighbor faces
    If this toggle is on, faces adjacent to the selected faces act as guides for the sides. Otherwise it moves along the face normal.
Example 1
In this example the selected face is offset for a negative distance with duplicate option.
Input
Output (actual body shown in transparency)
Move boundary along neighbor faces - OFF
Move boundary along neighbor faces - ON
Example 2
In this example the selected face is offset without duplicate option.
Input
Output
Offset for a negative distance.
Offset for a positive distance.
