Coordinate
Note: This section is only applied to the Inner
Magnet part.
Defines the coordinate system for magnet polarization. Typically, align the x-axis with the part's centerline, setting the rotation center and angle along the Z-axis.
Note: Only global or C.Rotation type
local coordinate systems are accepted for magnet polarization. The coordinate
system ID can be selected in the next step.
