Apply Changes
- The system generates sketches and bodies.
- In the Assembly Browser, an editable sketch appears in the Sketch environment.
- In the Solution Browser, all new bodies are automatically assigned to the FluxMotor solution.
Note: Users may bypass template selection by directly creating
a basic sector in the Sketch environment using the
required parameters (OD, ID,
PN/SN). In this case, manual
assignment of all bodies to the FluxMotor solution is required. To edit
or enhance a generated sketch, simply modify it within the
Sketch environment.
For example, for the Inner Magnet Catalog:
