Scale
Resize parts in your model, which is useful when working with an imported model that is associated with a different default unit system.
On the Geometry ribbon, select the
Scale tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the currently displayed tool.
- Click and hold the currently displayed tool.
- Select
- Select the part to scale.
Enter a scaling factor in the microdialog.
For example, a factor of 1.5 will produce a part 150% the size of the original.
Click Apply
Create or Assign Variables to Parametrize a Model
Create or assign variables to parametrize a model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools and contexts.
Keyboard Shortcuts & Mouse Controls
To | Do this |
Add to or remove from the selection | Ctrl |
Select a point on a face as the scaling center | Shift |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
