Intersect Curves
Split intersecting curves or wire bodies into several curves.
On the Geometry ribbon, select the Intersect tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select at the lower right corner of the currently displayed tool.
- Click and hold the currently displayed tool.
- To combine all targets and newly created curves, in the guide bar select Options , then turn on Combine Curves.
- Select the target curves, then select Tools on the guide bar.
- Select the tool curves, then select Apply .
- Select the curves to remove, then select Apply.
