Extend Curve
Extend a curve and modify the shape of the extension.
                On the Geometry ribbon, select the Extend Curve
                        tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
 at the lower right corner of the
                                currently displayed tool. - Click and hold the currently displayed tool.
The guide panel appears.
 - Select
                Select a curve or the edge of a surface or face. To deselect, hold down
                        Ctrl while clicking or, in the guide panel, click
                To extend the curve at the opposite endpoint, select
                    Switch Endpoints. -
                Choose an extension shape.
- Linear Shape (default): The extension is a segment.
 - Soft Shape: The extension has continuous curvature.
 - Reflective Shape: The extension is the mirror image of the curve.
 - Natural Shape: The original curve is extended.
 - Arc Shape: The extension is shaped like an arc.
                Choose an extension method.
- Extension Distance (default): Select this option to enter the length of the extension itself.
 - Increment Factor: Select this option to enter an increment factor, which increases the length by a percentage. For example, if you enter a value of 0.1, the length increases by 10%.
 - Total Length: Select this option to enter the total length of the curve.
 - Up to Curve/Surface: Select this option to select the curve or surface to extend up to.
                Based on your previous selection, modify the extension.
Method Do this Extension Length Enter the Length of the extension itself. Increment Factor Enter an increment Factor, which increases the length by a percentage. For example, if you enter a value of 0.1, the length increases by 10%. Total Length Enter the total Length of the curve. Up to Curve/Surface - Next to Ex. Up to, click the Select button.
 - In the modeling window, select the curve or surface
                                                up to which you want to extend the curve. To clear
                                                the selection, click
 - To make the extension a new part, turn on Create New Part.
