Error Detected While Processing Geometry
Condition
One or more geometric features on the parts used in your motion contacts prevents it from satisfying the conditions required by the solver.
Cause
The part listed has geometry that could not be processed properly for motion contacts.
- Click Review to change the part's Resolution in the Property Editor.
- Split your part into simpler pieces, for example, using the Cut or Partition tool. This can help you pinpoint the problematic region of the geometry.
- Try replacing portions of the part with simplified primitive geometry such as a cylinder, box, or sphere.
