Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest
solutions when problems are found.
There are a number of problems that can prevent analysis or optimization from running successfully. The most common
reasons for failed runs are improperly defined load cases.
Note: Check the run.log file located in the File > Preferences > Inspire > Analysis > Run History Path. (The support team will want to review this
file.)
