Statics Analysis Is Not Converging for Your Model
Condition
The static solver was unable to find a static equilibrium position during analysis of this model.
Remedy
- Run a transient simulation instead to see if you have a freely falling body in your model.
- Try changing the Model Units to the MKS or MMKS units system. Modeling units can be changed via .
- Add soft coil springs to stabilize parts and help them settle out during statics analysis.
- Turn gravity off and see if you can find statics successfully.
- Use transient analysis to bring your model closer to a static position, then use the Update Model feature to use that configuration as a new starting point for subsequent statics analysis.
- Check the run.log file located in the .
- You may have a part with an unconstrained rotational degree of freedom. Try placing a soft torsion spring on the part to prevent it from spinning during statics analysis.
