Coil Spring/Damper Endpoints Too Close or Crossed
Condition
The coil spring or damper's endpoints have been positioned in a way that exceeds the spring's limits or are crossed.
This error message has two versions:
- Coil Spring Endpoints Too Close or Crossed
- Damper Endpoints Too Close or Crossed
Remedy
- Enable Spring Limits under General in the Property Editor (springs only).
- Increase the spring's Stiffness property under Spring Limits in the Property Editor.
- Use the Move tool or endpoint manipulators to separate the endpoints so they won't get too close or cross during analysis.
- Change the unit system (e.g. from SI to MPA).
