Stiction Transition Velocity Exceeds Friction Transition Velocity
Remedy
  • For rigid joints, change the friction transition velocity so it is greater than or equal to the stiction transition velocity under Friction Effect in the joint friction properties.
  • For motion contacts, change friction transition velocity so it is greater than or equal to the stiction transition velocity on the motion contacts microdialog, table, or Property Editor.
