Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest
solutions when problems are found.
There are a number of problems that can prevent analysis or optimization from running successfully. The most common
reasons for failed runs are improperly defined load cases.
There is a syntax error in the solver expression entered for the
Profile Function in a motor or actuator. Open the Property Editor to
review the expression for errors.
