/SENSOR/TEMP
Block Format Keyword Describes a sensor activated when the temperature in a group of nodes reaches one of the prescribed limit values during a minimum time duration.
| /SENSOR/TEMP/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| Grnod_ID | Tempmax | Tempmin | Tempmean | Tmin | |||||
Definition
| sens_ID | Sensor identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| sens_title | Sensor title. (Character, maximum 100 characters) |
| Tdelay | Time delay. Default = 0.0 (Real) |
| Grnod_ID | Node group
identifier. (Integer) |
| Tempmax | Maximum temperature
limit. Default = 1E+20 (Real) |
| Tempmin | Minimum temperature
limit. Default = 0 (Real) |
| Tempmean | Average temperature
| Tmin | Minimum time duration before
activation when criteria is reached. Default = 0 (Real) |
- Sensors can be used to terminate a simulation at specific conditions with the Engine keyword /STOP/LSENSOR.
- The sensor is activated when one the following conditions is
reached:
- Maximum of nodal temperature > Tempmax during time > Tmin + Tdelay
- Minimum of nodal temperature < Tempmin during time > Tmin + Tdelay
- Average temperature of node group > Tempmean during time > Tmin + Tdelay
