/SENSOR/ENERGY
Block Format Keyword Describes the sensors used to activate or deactivate an object according to energy.
| /SENSOR/ENERGY/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| part_ID | subset_ID | Iselect | |||||||
| IEmin | IEmax | KEmin | KEmax | Tmin | |||||
| IEtol | IEtime | KEtol | KEtime | ||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| part_ID | Part identifier for
the part monitored for
/SENSOR/ENERGY. (Integer) |
| subset_ID | Subset identifier for
the subset monitored for /SENSOR/ENERGY, used
if part_ID is not defined. If part_ID and subset_ID are not defined and Iselect = 1, internal and kinetic energy are from all meshed parts in the model. (Integer) |
| Iselect | Subset or global
energy selector.
(Integer) |
| IEmin | Minimum part or subset
internal energy. Default = -1E+30 (Real) |
| IEmax | Maximum part or subset
internal energy. Default = 1E+30 (Real) |
| KEmin | Minimum part or subset
kinetic energy. Default = -1E+30 (Real) |
| KEmax | Maximum part or subset
kinetic energy. Default = 1E+30 (Real) |
| Tmin | Minimum time duration
before activation when criteria is reached. 5 (Real) |
| IEtol | Tolerance for constant
internal energy definition. (Real) |
| IEtime | Minimum time duration
for activation when constant internal energy is
reached. Default = 1E+30 (Real) |
| KEtol | Tolerance for constant
kinetic energy definition. (Real) |
| KEtime | Minimum time duration
for activation when constant kinetic energy is
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements with /ACTIV.
- Sensors can be used to generate animations or h3d frames at specific conditions with the Engine keywords /ANIM/LSENSOR or /H3D/LSENSOR.
- Sensors can be used to terminate a simulation at specific conditions with the Engine keyword /STOP/LSENSOR.
- For sensor type
ENERGY.The sensor is activated when the internal or kinetic energies satisfy the criteria for the defined part or subset.
- Internal energy < IEmin or Internal energy > IEmax during time > Tmin
- Kinetic energy < KEmin or Kinetic energy > KEmax during time > Tmin
- Internal energy is constant during IEtime with tolerance IEtol around the mean value
- Kinetic energy is constant during KEtime with tolerance KEtol around the mean value
