/SENSOR/HIC
Block Format Keyword Describes the sensors used to activate or deactivate an object according to Head Injury Criteria (HIC).
| /SENSOR/HIC/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| accel_ID | DIR | ||||||||
| Period | Value | Gravity | Tmin | ||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| accel_ID | Accelerometer
identifier. (Integer) |
| gauge_ID | Gauge
| DIR | Force direction.
(Integer) |
| Period | Time window for the
HIC. Default = 0.036, if in SI unit (Real) |
| Value | HIC
limit value. Default = 1E20 (Real) |
| Gravity | Time window for the
HIC. Default = 9.80665 if in SI unit (Real) |
| Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type
HIC, criteria is computed with:
With and .
The sensor is activated when after Tmin value.
