/SENSOR/SECT
Block Format Keyword Describes the sensors used to activate or deactivate an object according to section force.
| /SENSOR/SECT/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| sect_ID | DIR | Fmin | Fmax | Tmin | |||||
Definition
| sens_ID | Sensor
                                        identifier. (Integer, maximum 10 digits)  |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits)  |
| sens_title | Sensor
                                        title. (Character, maximum 100 characters)  |
| Tdelay | Time
                                        delay. (Real)  |
| sect_ID | Section
| DIR | Force direction.
 (Integer)  |
| Fmin | Minimum
                                        force. Default = 0 (Real, maximum 20 fields)  |
| Fmax | Maximum
| Tmin | Minimum time duration
                                    before activation when criteria is reached. 3 (Real)  |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
 - Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
 - For Sensor type
                        SECT:Sensor is activated when section force satisfies the criteria:
- or during Tmin
Dir defines Force direction:- TF
 - Total Force
 - TM
 - Total Moment
 - FN
 - Normal Force
 - FT
 - Tangent Force
 - FX
 - Force in X direction
 - FY
 - Force in Y direction
 - FZ
 - Force in Z direction
 - MX
 - Moment in X direction
 - MY
 - Moment in Y direction
 - MZ
 - Moment in Z direction
 - Values for force and moment component limits in the force-based sensors (SECT) can be positive and negative. Normal, tangent, total force and moment values are always positive.
