/SENSOR/SENS
Block Format Keyword Describes the sensors used to activate or deactivate an object according to another sensor.
/SENSOR/SENS/sens_ID/unit_ID
sens_title
Tdelay
sens_ID1 sens_ID2
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
sens_ID1 Activation sensor identifier IS1.
(Integer)
sens_ID2 Deactivation sensor identifier IS2.
(Integer)
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor types SENS:
    • The sensor is activated after activation of sensor sens_ID1.
    • Minimum activation duration is given by Tdelay.
    • After Tdelay, sensor is deactivated if sens_ID2 is activated.
    • If sens_ID2=0, the sensor is deactivated after Tdelay.
      clip0129
