/SENSOR/GAUGE
Block Format Keyword Describes the sensors used to activate or deactivate an object according to pressure gauge.
| /SENSOR/GAUGE/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| Ngau | |||||||||
If Ngau > 0: Define Ngau Gauge Reference per line:
| gauge_ID | Pmin | Tmin | |||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| Ngau | Number of gauges (Ngau ≤
6). (Integer) |
| gauge_ID | Gauge
identifier. (Integer) |
| Pmin | Minimum absolute value
of pressure. (Real) |
| Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type
GAUGE:
- Sensor is activated (at Tstart) if one of the gauges gives a
presure greater than Pmin during a time greater than
Tmin.
Tsensor = Tdelay + Tstart
- Tstart is the time when pressure criteria is reached.
Tmin.
