*DATABASE_NODAL_FORCE_GROUP
LS-DYNA Input Interface KeywordDefine a time history to output reaction forces for a set of nodes.
(1) (2) (3) (4) (5) (6) (7) (8)
NSID CID
Definition
NSID Node set identifier.
(Integer)
CID Local coordinate system identifier used for output.
(Integer)
  1. This keyword maps to /TH/NODE.
