*DATABASE_EXTENT_BINARY
LS-DYNA Input Interface KeywordDefine the results written in the animation output files.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*DATABASE_EXTENT_BINARY_{OPTION} |
If OPTION = COMP, insert the following line and
do not include any more input lines.
IVEL | IACC | ISTRS | ISTRA | ISED |
If OPTION = BLANK, include the following four
lines.
STRFLG | SIGFLG | EPSFLG | RLTFLG | ENGFLG | |||
DCOMP | SHGE | STSSZ | |||||
PKP_SEN | MSSCL | THERM | NODOUT | ||||
DTDT |
Definition
OPTION |
IVEL | Nodal velocity output.
IACC | Nodal acceleration output.
ISTRS | Stress tensor and plastic strain output.
ISTRA | Strain tensor output.
ISED | Specific energy output.
STRFLG | Strain tensor output.
SIGFLG | Stress tensor output.
EPSFLG | Plastic strain output.
RLTFLG | Equivalent strain output.
ENGFLG | Specific energy and shell thickness output.
DCOMP | Animation file compression.
SHGE | Hourglass energy output.
STSSZ | Element time step, mass, or added mass.
PKP_SEN | Contact pressure output.
MSSCL | Mass scaling output.
THERM | Temperature output.
NODOUT | Grid point output.
DTDT | Temperature nodal output and time step.
- This keyword maps to /ANIM options.
