*DATABASE_HISTORY_NODE
LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DATABASE_HISTORY_NODE_{OPTION} | |||||||
If OPTION = None (not defined)
| NOD_ID1 | NOD_ID2 | NOD_ID3 | NOD_ID4 | NOD_ID5 | NOD_ID6 | NOD_ID7 | NOD_ID8 |
| Etc. |
If OPTION = SET
| SET_ID1 | SET_ID2 | SET_ID3 | SET_ID4 | SET_ID5 | SET_ID6 | SET_ID7 | SET_ID8 |
| Etc. |
If OPTION = LOCAL
| NOD_ID1 | CID | REF | |||||
| NOD_ID2 | CID | REF | |||||
| etc. |
If OPTION = SET_LOCAL
| SET_ID1 | CID | REF | |||||
| SET_ID2 | CID | REF | |||||
| etc. |
Definition
| OPTION |
| NOD_IDi | Node identifier. (Integer) |
| SET_IDi | Node set identifier. (Integer) |
| CID | Local coordinate system identifier used for
output. (Integer) |
| REF | The node output is in:
(Integer) |
- This keyword maps to /TH/NODE.
- A moving coordinate system based on nodes is used when REF=1.
- The SET_ID should contain only a list of nodes. It cannot be a set of set.
