LS-DYNA Input Interface KeywordThis keyword defines which entities are output to the time history file.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| *DATABASE_HISTORY_{OPTION1}_{OPTION2} |
If
OPTION2 =
None (not defined)
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| ELE_ID1 |
ELE_ID2 |
ELE_ID3 |
ELE_ID4 |
ELE_ID5 |
ELE_ID6 |
ELE_ID7 |
ELE_ID8 |
| etc |
If
OPTION2 =
SET
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| SET_ID1 |
SET_ID2 |
SET_ID3 |
SET_ID4 |
SET_ID5 |
SET_ID6 |
SET_ID7 |
SET_ID8 |
| etc |
Definition
| Field |
Contents |
SI Unit Example |
| OPTION1 |
(Required) Element type output.
- BEAM
- List of beam, truss, and discrete beam
elements.
- DISCRETE
- List of discrete beam elements.
- SOLID
- List of solid elements.
- SHELL
- List of shell elements.
- SEATBELT
- List of seatbelt elements.
- SPH
- List of SPH elements.
| OPTION2 |
(Optional) Input type.
- None
- Element ID’s are listed.
- SET
- Set IDs are listed.
| ELE_IDi |
Element identifier. (Integer) |
| SET_IDi |
Set identifier. (Integer) |
