*CONTROL_UNITS
LS-DYNA Input Interface KeywordDefines the input file unit system.
It is recommended to include this keyword.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTROL_UNITS
Length Time Mass
Definition
Length Unit Length:
= m (Default)
meters
= mm
millimeter
= cm
centimeter
= inch
inches (0.0254 m)
= foot
foot (0.3048 m)
(Text)
Time Unit Time:
= s (Default)
seconds
= ms
milliseconds
= micro_s
microseconds
(Text)
Mass Unit Mass:
= kg (Default)
kilogram
= g
gram
= mg
milligram
= mtrc_ton
metric ton
= lb
pound (0.45359237 kg)
= slug
pound * second2 / foot (14.5939029372 kg)
= slinch
pound * second2 / inch (175.126835244 kg)
(Text)
  1. This keyword is mapped to /BEGIN.
