*CONTROL_TIMESTEP
LS-DYNA Input Interface KeywordDefines time step control conditions.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTROL_TIMESTEP | |||||||
| TSSFAC | DT2MS | LCTM | |||||
Definition
| TSSFAC | Scaling coefficient for the time step. (Real) |
| DT2MS |
(Real) |
| LCTM | Curve identifier to define the maximum time step value. Only
the initial and maximum ordinate value of the curve are
used. (Integer) |
- This keyword maps to /DT/NODA/CST and /DTIX.
- Resulting starting timestep will be = to TSSFAC * DT2MS * -1.
