Split, Swap, Combine Elements
Use the Edit Elements: Split tool to split quad elements and edges, combine tria elements, and swap element edges. Second order 2D and 3D elements are also supported.
From the 2D ribbon, click the tool.
Elements are colored according to how well they adhere to the pre-set quality requirements defined in the criteria file. - Optional:
On the guide bar, click to
to define the options used to
edit elements.
- Optional:
Find all elements at or below a certain quality level.
- Click Find on the guide bar.
Increase or decrease the number of layers around patches of failed
elements by clicking
or
on the guide bar.
Review the next or previous patch of failed elements by clicking
or
on the guide bar.
Select a split method from the guide bar drop-down
menu.
Option Description Quality - Split an element or element edge by left-clicking.
- Swap an element edge by holding Ctrl while left-clicking on an element or edge. Additional clicks will cycle through the possible edge positions.
- Combine two tria elements by holding Shift while left-clicking on their shared edge.
Graphical Lines - Draw continuous single or multiple graphical split lines.
- Click Split.
Plate - On the guide bar, click to
to define the
options used to split elements. - Select elements to split.
- Select plate method.
- In the microdialog, divide quad elements into trias based on the advanced split
option selected.
- Shortest
- Split quad element into tria elements using the shortest possible diagonal.
- Aligned
- Align the diagonals of all the tria elements in the same direction.
- Unionjack
- Split quad elements into tria elements so their diagonals create a unionjack pattern.
- Largest angle
- Split quad elements into tria elements using the largest angle diagonal.
- Reverse the direction of the split.
- Click Split.
Figure 3.
Note: When you split elements at fillets or curved faces, the middle nodes are projected back to parent edges/surfaces by default upon splitting.Figure 4.
Solid - Select the elements to split.
- Select a method for splitting solid elements.
- Hexas: refine the selected hexa elements by subdividing each hexa into smaller hexa elements.
- Tetras: split selected hexa elements into the minimal number of tetra elements.
- Symmetric: split selected hexa elements into symmetric tetra sets optimized for CFD applications.
- Click Split.
All split operators work on both first and second order elements.
Layer - Select nodes to define the direction of
split/combine/delete.
Two subsequent node selections define a direction. You can select multiple node pairs simultaneously, but they should be neighboring nodes. You can use By Path in Advanced Selection to define multiple splits and works for split only.
- Select a layer method.
- Split: split hex elements along edges. You can select options for biasing while splitting layers.
- Combine: combine neighboring elements.
- Delete: delete layers of elements.
- Diagonal: split a single element along the diagonal.
- Optionally, select the Elements check box and select elements to split.
- Click
Combine - Select the elements to split.
- Click Combine.
Tip: You can toggle graphical previews from the options menu.
