Read .h3d Node Positions
Use the Read Positions tool to read .h3d node positions.
For every task, with the exception of creating a table, once the solver run is finished you will import the new node positions, and in the stitching the new connectivity, from the .h3d file generated.
Restriction: This tool is designed for working with models in the kg, mm, ms
unit system.
- From the Airbag ribbon, click the satellite icon that appears when you hover over the tool.
- Enter a File name (.h3d file) and click Open.
