Create a Roll Fold
From the Airbag ribbon, click the
Roll tool.
Use the microdialog to define a folding line.
On the guide bar, click
to define
parameters.
- Number of rotations: The computation stops once this number is reached. Must be an integer.
- Angle (rotation direction)
- Tool Type: Select the tool that the airbag will be rolled around. This
can be either a flat strip (width) or a cylinder (diameter).
- Width/Diameter: Width or diameter of the strip or the cylinder, respectively.
- Tool offset: The distance between the tool and the airbag plane.
- Z translation of Rotation axis: Use this option when the area folded already has many layers that were caused by previous folds.
- On the guide bar, click Side node. The selected node defines the side that the airbag is folded on.
- On the guide bar, click Fixed nodes to select nodes that will be unaffected by the fold.
Set advanced selections as necessary by clicking
on the guide bar.
- On the guide bar, click Preview to preview the fold.
On the guide bar, click Save to
save the fold definition. This includes the position of the folding line, the
way it is folded, the Z offset, and the stop angle, for example.
The simple fold is displayed in the Airbag Solution Browser.
Figure 3.
