Parts View
The Parts view displays the CAE part structure/hierarchy information that is typically present in the model file as metadata.
This view consists of two panes; the top pane displays the model structure, part assembly, and part attributes and the bottom pane displays the Entity Editor. If part sets information is available in the model file, then it is displayed as a separate folder in the top pane.
By default, the following attributes are listed as columns in the first pane.
To add or remove columns, right-click on the column header to invoke the Configuration dialog, from which you can turn the display of columns on/off in the Columns tab.
Sort by a particular entity in the browser by clicking on the heading of each column. For fields that are numeric and/or alphanumeric, repeated clicks toggles between ascending and descending order.
Entities
List of the Model, Part Assemblies, Parts, and Components. By default, the browser is displayed in Hierarchical View.
ID
Displays the internal ID of entities (hidden by default).
Color
Displays the colors of entities.
UID
Displays the Part Assembly and Part Unique IDs.
Representation
Displays the in-session/loaded representation (hidden by default).
CID
Displays the entity specific Component ID’s. At the Part level it displays IDs for owned components. At Component level it shows the ID of components.
PID
Displays the entity specific Property ID’s. At the Part level it displays IDs for referenced properties. At Component level it shows the ID of the referenced property.
MID
Displays the entity specific Material ID’s. At the Part level it displays IDs for referenced materials. At Component level it shows the ID of the referenced material.
Material
Displays the material name.
Thickness
Displays the entity specific thickness. At the Part level it displays the thicknesses of the referenced properties. At Component level it shows the thickness of the referenced property.
PDM metadata captured upon the import will also be listed as columns.
PDM PID
PDM Property ID metadata.
PDM MID
PDM Material ID metadata.
PDM Material
PDM Material name metadata.
PDM Thickness
PDM Thickness metadata.
To select a Part, go to Idle Mode and select the Part graphically to view it in the browser tree, or conversely, select the Part in the browser tree to view it in the modeling window.
Entity Editor Part Entity View
Name Entity
Color Color
Unique ID UID
Representation Representation
Component ID CID
Property ID PID
Material ID MID
Material Material
PDM PID PDM PID
PDM MID PDM MID
PDM Material PDM Material
PDM Thickness PDM Thickness
Entity Editor
Edit part and component attributes in the Entity Editor.
Certain representation data and PDM data attributes displayed in the Entity Editor correspond to the columns displayed in the first pane above the Entity Editor. This relationship is shown in the table below.
The following types of data are displayed in the Entity Editor:
General Data
Displays attributes that are unique to the part or assembly, including part/assembly name, Unique ID (UID), and color.
Parts and part assemblies require a unique name and a unique identifier (UID), both of which can contain alphanumeric characters. The UID is an optional field that is utilized in part representation management and import model entity management. For example, when merging a component with a part (module), the two entities will be matched using the UID if it exists. If a UID does not exist, merging will be based on the part name.
Representations Data
Displays attributes that are specific to a part representation, such as representation name, file location, property ID, and material ID/name. These attributes are non-editable at the part level.
Position Data
Displays the 4 x 3 transformation matrix of a part, namely its translation, rotation, and scaling. These attributes are non-editable.
PDM Data
Displays PDM attributes that were parsed as metadata during the BOM importation, such as PDM ID and PDM Revision. This information is used to generate the initial component, property, and material cards upon creation of the common representation. These attributes can be used to cross-reference common and discipline specific mesh representation attributes.
