Load a Model and a Single Result from the Same File
- From the Load Model panel, activate the Load model and Load results check boxes.
- Click the file browser button, , next to Load model and select an animation file. The corresponding results file is automatically loaded.
Click Apply.
The model is loaded. A model content table and results table is created for post-processing.
