Load a Results File Containing Multiple Blocks
- From the Load Model panel, activate the Load model and Load results check boxes.
                Click the file browser button,
, next to Load
                        model and select an animation file.
, next to Load
                        results and select a results file.
                Click Apply. If the model contains more than one data
                    block, you will be prompted to select the desired block.
                The model is loaded. A model content table and results table is created for post-processing.
