Control the Stacking Order of 2D Image Planes
- From the 2D Image Plane tab, click the Z-Stack sub-tab.
Select an item in the list and use the arrow buttons located on the right side
of the sub-tab to move the item up or down the list.
The item at the top of the list (above <<MODEL>>) will be placed in the foreground of the graphics area, while the item(s) below are placed in the background (based on their order in the list).Note: <<MODEL>> represents the analysis models loaded into HyperView and drawn in the modeling window. If multiple models are overlayed, they will only be displayed as one item (<<MODEL>>) in the list.
