Set Current Model
When more than one model is loaded in a window, you can choose which model will be the current model.
This makes the panel functions available to the current model.
The results for the current load case of the active model will be displayed in the Results folder in the Results Browser, if the Model View is selected. Or you can select the Result View in order to only display the available results (on the current load case) in the Results Browser. See the Entity Views in the Results Browser topic for additional information.
