Connector Import
Learn about importing connector files.
The following file types can be imported: *.mwf,
                    *.mcf, *.xml,
                    *.vip, *.csv.
        Note: An xMCF file can be imported via an
.xml file that
                    contains the following
                        headline:<xmcf xmlns:xs="http/www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http:
    <version>3.0.0</version>
    <data>2015-12-14</date>xMCF is a connector solver
                        import format that is defined by the FAT.
Imported metadata
                        is mapped to each connector with HyperMesh
                        metadata. The imported information is managed in the Entity Editor and applied to the appropriate
                        realizations. Figure 1.
For xMCF files, the following types of
                        connectors and features are managed:
- 0D: Spotweld, bolt, screw, gumdrop, clinch, rivet (blind, self-piercing, solid, swop), robscan, contact_list, threaded connection, heat stake, clip, nail
- 1D: Sequence connection 0D (spotweld, gumdrop), seamweld (butt_joint, corner weld, edge weld, i_weld, overlap weld, y-joint, k-joint, cruciform joint, flared joint), adhesive-line, hemming, contact list
- 2D: Adhesive face
- Custom attributes are managed.
- Appdata is not managed.
