2026
Import various file types into the selected client.
Import FE models for supported solver interfaces.
View new features for Altair HyperWorks 2026.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Learn about the supported CAD readers and the options available for importing CAD geometry data.
Overview of how entities are imported.
When an external input translator is used to import data, the application creates a file for messages in the directory in which the program was started.
An overview of how solver interfaces use the Create components by HyperMesh comments import option.
IDs that are duplicated within element and property groups for the LS-DYNA user profile are supported in the application.
Learn about importing connector files.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in the application.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
The Diagnostics Information Gathering utility collects diagnostics files in the case of a crash and saves them to a common folder.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Templates can be imported by means of the File > Import menu.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
