Elements
              | LS-DYNA |
              OptiStruct |
              | *ELEMENT_MASS  |
              CONM2 |
              | *ELEMENT_BEAM  |
              CBAR  |
              | *ELEMENT_SHELL |
              CTRIA3,CQUAD4, CQUAD8, CTRIA6 |
              | *ELEMENT_SOLID |
              CTETRA4/CHEXA8/CPENTA6 |
              | *CONSTRAINED_SPOTWELD |
              RBAR |
              | *ELEMENT_PLOTEL  |
              PLOTEL |
              | *CONSTRAINED_INTERPOLATION  |
              RBE3 |
              | *CONSTRAINED_NODE_SET |
              RBE2 |
              | *ELEMENT_DISCRETE |
              CELAS1 |
    Properties
              | LS-DYNA |
              OptiStruct |
              | *SECTION BEAM(ELFORM=1) |
              PBEAML |
              | *SECTION_SOLID |
              PSOLID |
              | *SECTION_SHELL |
              PSHELL |
              | *SECTION TSHELL |
              PSOLID |
    Materials
              | LS-DYNA |
              OptiStruct |
              | *MAT_MODIFIED_PIECEWISE_LINEAR_ELASTICITY |
              MATS1 |
              | *MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY |
              MAT1,MATS1,TABLEMD |
              | *MAT_TABULATED_JOHNSONCOOK |
              MATS1 |
              | *MAT_PIECEWISE_LINEAR_PLASTICITY |
              MAT1,MATS1 |
              | *MAT_PLASTICITY_COMPRESSION_TENSION |
              MATS1 |
      All the LS-DYNA materials are mapped MAT1 in OptiStruct.
    Loads
              | LS-DYNA |
              OptiStruct |
              | *BOUNDARY PRESCRIBED MOTION |
              SPCD |
              | PLOAD |
              PLOAD4,PLOAD2,TABLED1,TLOAD |
    Joints
              | LS-DYNA |
              OptiStruct |
              | Spherical |
              Ball |
    Boundary Conditions
              | LS-DYNA |
              OptiStruct |
              | *BOUNDARY_SPC |
              SPC |
              | *LOAD_NODE_POINT |
              FORCE, MOMENT |
              | *LOAD_SEGMENT |
              PLOAD4 |
              | *INITIAL_TEMP |
              TEMP |
    Coordinate Systems
              | LS-DYNA |
              OptiStruct |
              | *DEFINE_COORDINATE_NODE |
              CORD1R |
              | *DEFINE_COORDINATE_ SYSTEM   |
              CORD2R |
    Cards
                | LS-DYNA |
                OptiStruct |
                | *CONTROL TIMESTEP |
                 /DY/NODA/CST |
                | *CONTROL TERMINATION |
                TSTEPE |
    Contacts
                | LS-DYNA |
                OptiStruct |
                | *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE |
                CONTACT,AUTO |
