LS-DYNA to Nastran Conversion Mapping
Elements
LS-DYNA | Nastran |
*ELEMENT_MASS | CONM2 |
*ELEMENT_INERTIA | CONM2 |
*ELEMENT_BEAM | CBAR |
*ELEMENT_SHELL | CTRIA3,CQUAD4, CQUAD8, CTRIA6 |
*ELEMENT_SOLID | CTETRA4/CHEXA8/CPENTA6 |
*CONSTRAINED_SPOTWELD | RBAR |
*ELEMENT_PLOTEL | PLOTEL |
*CONSTRAINED_INTERPOLATION | RBE3 |
*CONSTRAINED_NODE_SET | RBE2 |
*ELEMENT_DISCRETE | CELAS1 |
Properties
LS-DYNA | Nastran |
*SECTION_SOLID | PSOLID |
*SECTION_SHELL | PSHELL |
*SECTION_BEAM | PBAR, PBARL |
*SECTION_BEAM with ELFORM 1 is mapped to the PBARL property.
*SECTION_BEAM with ELFORM 2 is mapped to the PBAR property.
Materials
All the LS-DYNA materials are mapped MAT1 in Nastran.
Boundary Conditions
LS-DYNA | Nastran |
*BOUNDARY_SPC | SPC |
*LOAD_NODE_POINT | FORCE, MOMENT |
*LOAD_SEGMENT | PLOAD4 |
*INITIAL_TEMP | TEMP |
Coordinate System
LS-DYNA | Nastran |
*DEFINE_COORDINATE_NODE | CORD1R |
*DEFINE_COORDINATE_SYSTEM | CORD2R |
