User sub routines (Groovy): list of variables
Physical Parameter .groovy
Here are the settings of “PhysicalParameter.groovy”:
| Variable | Type | Size | Informations |
| inputValues | Double[] | 0:n-1 | The n arguments of the “User” function. |
| outputValue | Double |
Material Law.groovy
Here are the settings of “MaterialLaw.groovy”:
| material | String | The name of the material | |
| userCoeff | Double[] | n | The n user coefficients |
| paramSpatialCurrent | Map [k,v]* | n | The n spatial quantities |
| paramIOCurrent | Map [k,v] | n | The n I / O parameters |
| nbReal | Integer | This points out if the problem is real (1) or complex (2) | |
| nbComponent | Integer | This points out if the variable is scalar (1) or vector (3) | |
| varin | Double[][] | nbReal x nbComponent | This is the input variable, computed by Flux |
| varou | Double[][] | nbReal x nbComponent | This is the output variable, computed by the user model |
| tensor | Double[][][] | nbReal x nbComponent x nbComponent |
This is the output tensor, computed by the user model |
| iostatus | Integer | This points out an error to the user, if its value is different from 1 or 2 |
* For each value v, there is an appropriate key k. k represents the name of the spatial quantity and this map is used as follows: paramSpatialCurrent [“k”] = v.
Hysteresys Material Law.groovy
Here are the settings of “HysteresysMaterialLaw.groovy”:
| paramSpatialCurrent | Map [k,v] | n | The n spatial quantities |
| step | Integer | This points out the step of the computation process (1 to 8) | |
| arrayDSize | Integer | This points out the size of the arrayD table | |
| arrayISize | Integer | This points out the size of the arrayI table | |
| arrayD | Double[] | arrayDSize | Work table |
| arrayI | Integer[] | arrayISize | Work table |
| coordPoint | Double[] | 3 | The coordinates of the Gauss point |
| times | Double[] | 2 |
This points out the time step :
| tensor | Double[][][] | nbReal x nbComponent x nbComponnt | This is the output tensor, computed by the user model |
| iostatus | Integer | This points out an error to the user, if its value is different from 1 to 8 |
