Construction tools: chamfer
Chanfrein
The sketcher mode of construction « Chamfer » permits the user to cut a corner by inserting a segment. This chamfer can be defined in 3 different manners:
  • equal distance
  • distance – distance
  • distance – angle
Preview
Equal distance Distance – distance Distance – angle
Access / Cursor
The different accesses and personalized cursor for this mode of creation are presented in the following table:
Accès Curseur
Par icône:
Par menu: Outils → Chanfrein
Dialog box
After the activation of this mode, a dialog box containing all the necessary fields and options to apply a chamfer will appear.
Illustration
Graphic selection Permits the user to choose the both necessary lines (mandatory segment type) by selecting them graphically*
Distance de la 1 ère ligne Distance which is applied on the two selected lines
Distance which is applied on the 1 st selected line
(in this case the Line 16)
Distance de la 2 ème ligne
Distance which is applied on the 2 nd selected line
(in this case the Line 19)
Angle par rapport à la 1 ère ligne Angle which is applied between the 1 st selected line and the future line
*It is possible to deselect the entities graphically or by using the button Delete.
Apply a chamfer
The process to apply a Chamfer is presented in the table below.
Stage Description
1 Activation of the mode
→ A dialog box is opened
2 Graphic selection of the two segments representing the corner to cut
The field « Graphic selection » is filled in
The selected entities are highlighted in green.
3 Choice of the sketcher mode of definition (equal distance, or distance – distance, or distance – angle)
→ The dialog box adapts itself by displaying the necessary fields following the chosen mode of definition
4 Choice of fields of definition (to enter)
The fields are filled in
The chamfer outline will appear
5 Validation of the chamfer by OK
The dialog box closes.
The both origin segments arte modified.
A third segment is added between both the origin segments representing the chamfer.
The mode of construction is automatically deactivated.
Variant : Select the entities to be repeated before activating the mode permits to open the dialog box with the field « Graphic selection » pre-filled
