Steps for iron losses multiparametric computation
This section describes the steps to carry out multiparametric computation of iron losses:
- Choose Multiparametric on regions as Computation type
- Select the laminated regions for iron losses computation
- Choose:
- Intervals of values for geometric parameters and I/O parameters after having checked the corresponding boxes (or fixed parameters values)
- In Transient Magnetic applications: the time interval to obtain a time period. This choice is linked with the field Part of cycle described by the time interval
- In Transient Magnetic applications, define what the time interval selected at the previous step represents. The various possibilities are presented in the table of the page: Steps for iron losses computation on regions
- Choose the model for losses:
- Model defined in material
- Modified Bertotti: enter the coefficient values and modify exponents if necessary
- LS predefined sheets (in Transient Magnetic): enter the sheet iron
- LS defined by importing a MILS file (in Transient Magnetic, see LS model identification with MILS)
