Activate / inactivate Aided mesh
Inactivate
To inactivate the aided mesh:
Step Action
1 Activate the Mesh / Aided mesh / Edit command
→ The aided mesh box is opened.
2 Select Inactivated in the field "State of aided mesh"
3 Click on Apply
→ The aided mesh is inactivated. If the by default values have been modified, these modifications are not saved in the memory in case of re-activation.
Activate
To activate the aided mesh:
Step Action
1 Select the string Mesh / Aided mesh / Edit
2 Select Activated in the field "State of aided mesh"
3 Click on Apply
→ The aided mesh is activated.
