Structured faces
Important!!!
The faces created by Flux using the algorithms of automatic construction are faces belonging to planar surfaces.
Automatic faces / structured faces
The faces created using the algorithms of automatic construction are named automatic faces.
The faces created using the construction by extrusion are named structured faces.
Structured faces
The building of a structured face is shown in the figure below:
where:
  • bottom line is the source
  • upper line is the image
  • side lines are connection elements
