Construction by extrusion: about
Definition
The construction by extrusion is a building method that allows the construction of new geometric entities based on already existing entities by using a geometric transformation like translation, rotation, …
Notice
We deal with:
  • propagation, when the image object, generated by transformation, is not connected by lines to the source object
  • extrusion, when the image object, generated by transformation, is connected by lines to the source object
