Extrude points
Before starting
It is necessary to have a transformation (created beforehand) and points to be able to extrude points.
Extrude points
To extrude points:
Step Action
1
Select the points to extrude:
  • in the Select menu click on Select points
    (or on the icon )
  • in the graphic scene click on the point of interest
    (Keep pressed the Ctrl key for a multiple selection.)
2
Activate the command *:
  • open the contextual menu with the right mouse button
  • click on Extrude points in the contextual menu
→ A new dialogue box is opened.
3
Fill out the fields:
  • choose a transformation
  • enter the number of the successive executions of the transformation
  • choose the extrusion type (shape of the connection elements)
4
Validate the information:
  • click on OK button
→ The lines are created.
→ A new dialog box for the extrusion of entities of the same type is automatically opened.
5
Quit the sequence:
  • click on Cancel button
Note: * You can also activate the extrusion command by clicking on Extrude points in the menu Geometry > Extrude (or on the icon ).
