API Guide for Authors
The API Guide for Authors explains the usage of the plug-in from an Author's perspective. The Authors of API plug-ins can create a dialog box (window) within EDEM’s GUI that allows editing of parameters without the use of preference files or recompiling. This guide assumes that you are familiar with EDEM’s API and have a complete plug-in that can be compiled and seamlessly used within EDEM. For more information about the basics of EDEM’s API, see the Altair Community page before continuing with authoring plug-ins.
To update the API version, starting from the source code of a functioning
plug-in, ensure that the plug-in is updated to be using at least version 3.9 of
the relevant (either contact model or particle body force) API.
This is done by editing the values within the
GETEFINTERVACEVERSION()orGETCMINTERVACEVERSION()macros as follows:EXPORT_MACRO int GETCMINTERFACEVERSION() { static const int INTERFACE_VERSION_MAJOR = 0x03; static const int INTERFACE_VERSION_MINOR = 0x09; static const int INTERFACE_VERSION_PATCH = 0x00; return (INTERFACE_VERSION_MAJOR << 16 | INTERFACE_VERSION_MINOR << 8 | INTERFACE_VERSION_PATCH); }Note: This is a mandatory step to accesspluginParameterManagerand various functions that allow you to create a custom dialog box for your plug-in. -
To create an accessible dialog box for the plug-in, perform the following
steps:
- Enable the feature flag in the
setupfunction as follows:bool CApiContactModel::setup(NApiHelpers::CFlags<EApiContactFeatureFlags>& featureFlags, NApiHelpers::CFlags<NApi::EApiSolverFlags>& solverFlags, NApiHelpers::CFlags<NApi::EApiParticleShapeFlags>& particleShapeFlags, NApiHelpers::CSimpleString& physicsModelName, const char prefFile[], char customMsg[NApi::ERROR_MSG_MAX_LENGTH]) { featureFlags.enableFlag(EApiContactFeatureFlags::pluginGUIEnabled);Note: The ability to create a GUI with additional settings for the plugin Physics model is enabled with a feature flag.The icon for additional settings for Physics models in the EDEM GUI is now enabled. - Plug-in parameters are defined in the primary function
setApiParametersTemplate()which is a member function of both theIpluginContactModelV3_9_0andIpluginParticleBodyForceV3_9_0interface classes provided by EDEM. - To define the plug-in parameters, use
pluginParameterManageravailable in theIApiPluginParameterManager_X_X.hheader file.You must include this header file within your plug-in to access all the useful functionality that populates the plug-in dialog box.
- After opening this header file, the following group and subgroup names
are available:
- PARTICLE_PARTICLE
- PARTICLE_GEOMETRY
- PARTICLE_BODY_FORCE
- LIST_ALL_MATERIALS
- LIST_BULK_MATERIALS
- LIST_EQUIP_MATERIALS
- LIST_INTERACTIONS
- LIST_GEOMETRIES
- LIST_PARTICLES
These group names are protected and EDEM will populate the dialog box differently depending on how these group names are used. The group names are used to group the parameters that you wish to expose to the user according to how they are accessed in EDEM’s GUI and where they should be applied.
In order to populate the dialog box, you must interact with the interface
IApiPluginParameterManager_X_X. - Using the
apiManager, create a pointer to an instance of this class withinsetApiParametersTemplate(), and populate the dialog box with the parameters that you want to expose to the user as follows:void CApiContactModel::setApiParametersTemplate() const { auto* apiManager = getApiManager(); auto* pluginParamaterManager = apiManager->getParameterManager(); pluginParamaterManager->startGroup(NPluginParamsGroupNames::PARTICLE_PARTICLE); pluginParamaterManager->addDoubleValue(0.1, "Surface Energy", NApi::eSurfaceEnergy); pluginParamaterManager->endGroup(); - Access the
IApiPluginParameterManager_X_Xfrom thestarting()function to retrieve the values stored in the dialog box as follows:bool CApiContactModel::starting( int numThreads, char guiPath[NApi::GUI_FILE_MAX_LENGTH]) { auto* apiManager = getApiManager(); auto* pluginParamaterManager = apiManager->getParameterManager(); pluginParamaterManager->startGroup(NPluginParamsGroupNames::PARTICLE_PARTICLE); double surfaceEnergy = pluginParamaterManager->getDoubleValue("Surface Energy"); pluginParamaterManager->endGroup();
To use the key member functions of
IApiPluginParameterManager_X_X, you must browse the header directly.- Add parameters (typically used in
setApiParametersTemplate()):addDoubleValue()Adds a Double value to the dialog box and allows you to specify the name, default value, units, and min/max limits.
addIntegerValue()Adds an Integer value to the dialog box and allows you to specify the name,default value, and min/max limits.
addBoolValue()Adds a Boolean value to the dialog box and allows you to specify the name and default value.
addStringValue()Adds a String value to the dialog box and allows you to specify the name and default value.
addComboBoxValue()Adds a combo Box to the dialog box and allows you to specify the name and default value.
addComboBoxOption()Adds an additional option to a specified combo box and allows you to specify the name of the combo box option and the combo box to which it should be added.
- Get stored parameter values (typically used in the
starting()function):getDoubleValue()Retrieves the current double value set by the user.
getIntegerValue()Retrieves the current integer value set by the user.
getBoolValue()Retrieves the current Boolean value set by the user.
getStringValue()Retrieves the current String value set by the user.
getComboBoxValue()Retrieves the currently selected combo box value set by the user.
- Interact with Groups:
startGroup()Starts a group, to store parameters in. Allows you to either use a protected group name or specify your own. This will typically be used inside
setApiParametersTemplate()when first creating the groups and parameters.endGroup()Ends or closes a group. This will be used in both
setApiParametersTemplate()andstarting(), when you are done defining a group or closing it once you have retrieved the necessary data.openGroup()Opens an already existing group. This is used when accessing values set by the user. This will typically be used inside the
starting()function.getGroupCount()Returns the number of sub-groups defined within the current group. This is to be used when looping over all defined interactions. This will typically be used inside the
starting()function.openInteractionGroup()Opens an interaction group. You must specify the group index. The material names are passed in empty <> but the corresponding material names are populated, based on the provided group index. This will typically be used inside the
starting()function.
- Tables offer similar functionality to groups. Parameters are defined via
column headers instead of individual values using similar syntax. It is also
possible to define default rows, in which case those rows may still be
modified by the user, but not deleted.
startTable()Starts a table to store parameters and will be used inside
setApiParametersTemplate().endTable()Ends or closes a table and will be used in both
setApiParametersTemplate()andstarting(), when you have defined a table or closed after retrieving the necessary data.openTable()Opens an already existing table. This is used when accessing values set by the user. This will typically be used inside the
starting()function.getTableRowCount()Returns the number of table rows within the current table and is used when looping over all table rows to read values. This will be used inside the
starting()function.addTableDoubleColumnHeader()Adds a column of type Double to the table and allows you to specify the name, default value, and units.
addTableIntegerColumnHeader()Adds a column of type Integer to the table and allows you to specify the name and default value.
addTableBoolColumnHeader()Adds a column of type Boolean to the table and allows you to specify the name and default value.
addTableStringColumnHeader()Adds a column of type String to the table and allows you to specify the name and default value.
startTableRow()Starts a default table row definition. Parameters defined inside this row must match existing table column names, and will be used as the default values. You can still edit this default row’s content, but will not be able to delete the row. This will be used inside the
starting()function.endTableRow()Ends or closes a table row. This will be used in both
setApiParametersTemplate()and thestarting()function, when you have defined a default table row, or closed it after retrieving the necessary data.openTableRow()Opens an already existing table row and is used when accessing values set by the user. When a table row is open, values in that row are accessed the same as normal parameters, using the column names as identifiers. This will be used inside the
starting()function.
Use Functions
Use the files and functions described in the recommended order.
- Update your plug-in to be compliant with version 3.9 of the relevant API.
Add the
IApiPluginParameterManager_X_X.hheader to your plug-in. -
Add the
setApiParametersTemplate()function to your class. -
Obtain a pointer to an instance of the
IApiPluginParameterManager_X_Xto interact with withinsetApiParametersTemplate(). - Define your groups, tables, and parameters as required
IApiPluginParameterManager_X_Xto interact with, within thestarting()function. - Retrieve data as required for use within the rest of the plug-in.
Use Groups
You must define all parameters within one of the three Physics chain groups.
To define parameters in
setApiParametersTemplate()for the Particle-Particle, Particle-Geometry, and Particle Body Force groups, start the group before defining your parameters and close it as follows:pluginParamaterManager->startGroup(NPluginParamsGroupNames::PARTICLE_PARTICLE); pluginParamaterManager->addDoubleValue(1234.0, "Test Double 1", NApi::eForce); pluginParamaterManager->addBoolValue(true, "Test bool 1"); pluginParamaterManager->endGroup(); - Define a Double called ‘Test double 1’ and a Boolean called ‘Test bool 1’ with the default values '1234.0 ' and 'true' respectively.
To retrieve these values in the
starting()function, useopenGroup(),getDoubleValue(), andgetBoolValue()functions as follows:pluginParamaterManager->openGroup(NPluginParamsGroupNames::PARTICLE_PARTICLE); testDouble = pluginParamaterManager->getDoubleValue("Test double 1"); testBool = pluginParamaterManager->getBoolValue("Test bool 1"); pluginParamaterManager->endGroup();You are assigning the retrieved Double and Boolean values here to member variables that you can use in your plug-in as required. - To define parameters for material interactions, follow the same steps but first add an additional group to define a template that all the other interactions are based on.
To implement the
setApiParametersTemplate()function, perform the following steps:pluginParamaterManager->startGroup(NPluginParamsGroupNames::INTERACTIONS); pluginParamaterManager->startGroup(NPluginParamsGroupNames::INTERACTIONS_TEMPLATE); pluginParamaterManager->addDoubleValue(5678.0, "Test Double 2", NApi::eVelocity); pluginParamaterManager->addBoolValue(true, "Test bool 2"); pluginParamaterManager->endGroup(); pluginParamaterManager->endGroup(); -
To retrieve the data, perform an additional step as the material
interactions need to be looped over for all the defined interactions that
are unknown at the time of compiling the plug-in:
pluginParamaterManager->openGroup(NPluginParamsGroupNames::INTERACTIONS); // Loop over all the defined interactions for (int groupIndex = 0; groupIndex < pluginParamaterManager->getGroupCount(); ++groupIndex) { char material1Name[NApi::FILE_PATH_MAX_LENGTH]; char material2Name[NApi::FILE_PATH_MAX_LENGTH]; // Get the material names for the current interaction index (groupIndex) // and then retrieve the parameter data for that interaction pair pluginParamaterManager->openInteractionGroup(groupIndex, material1Name, material2Name); testDouble = pluginParamaterManager->getDoubleValue("Test double 2"); testDouble = pluginParamaterManager->getBoolValue("Test bool 2"); pluginParamaterManager->endGroup(); } pluginParamaterManager->endGroup();Note: Indenting within the code snippets in all of these steps is done for code legibility and is not mandatory.
