Custom Properties
A Custom Property is a named group of one or more numeric (double precision floating point) values with an associated unit type.
Custom Property | Example |
Contact | Contact duration, highest force during contact |
Geometry | Cumulative impact force, wear |
Particle | Residence time, temperature |
Simulation | Stickiness of a surface |
Attribute | Description |
Name | Indicates the unique name of the custom property. |
State | When you first add properties, they are defined as tentative. Tentative properties do not have space allocated for them. When simulation starts, tentative properties are finalized and space is allocated for them. |
Storage Type | Indicates the properties data type (currently always a C++ double). |
Number of elements | Indicates the number of elements. Usually a property has one element. A property with a position in 3D space would have three elements (X, Y, and Z). |
Units | Indicates the unit type. For example, length, temperature, charge, velocity, and so on. If the property has no unit, this is set to 'None'. |
Values | Indicates the initial values of the property. Double-click to change the value (provided the custom property is either still tentative or is a simulation property). For custom simulation properties, the Values section also indicates the value for the current Time Step. |
Any UDL that uses a custom property with the same name and category will share the property’s value(s) and have the ability to manipulate them, provided the two UDL definitions (name, units, number of elements, and data type) are identical. If two UDLs have different definitions, only the first UDL will load. The second UDL will not load and an error is displayed.
You can call the Value of a custom property and modify the Delta of a custom property. At the end of a simulation cycle, the Delta is added to the Value, and the Value is updated accordingly for the next Time Step .
