Particle Body Force User Defined Libraries
A Contact Model UDL consists of a shared library file and, optionally, a file containing preferences. Using the EDEM API, you can write and compile custom particle body forces as a User Defined Library (UDL) written in C/C++.
- Create a directory in which you want to save the new Particle Body Force project.
Copy the following header files into the directory that you have created:
IPlug-inParticleBodyForce.h
Plug-inParticleBodyForceCore.h
IPlug-inParticleBodyForceV3_9_0.h
Plug-inConstants.h
Helpers.h
Create a new class (
CNewParticleBodyForce
) derived from the Particle Body Force interface you want to use (for example,IPlug-inParticleBodyForceV3_9_0
Save the class declaration to a header file (for
example,
CNewParticleBodyForce.h
Implement all the methods defined in your header file and save as a
.cpp
file (for example,CNewParticleBodyForce.cpp
Create a new
.cpp
file with implementations of the methods inPlug-inParticleBodyForceCore.h
Save this file as
Create a new
.cpp
Save this file as
Use command line or create a makefile (or equivalent) to build and compile
.dll
(Windows) or.so
(Linux) library files. -
Ensure that the library and optional preferences file are saved in the Plug-in
model folder (as specified in
simulation_name.dem
file (only applicable for EDEM versions 2025.1 and higher). ), or in the same folder as the - Start EDEM and then select the required Particle Body Force Model category from the Interaction dropdown list in the Physics section.
Click the + dropdown list and then select the new
Particle Body Force Model .
The following methods are available in the Particle Body Force Model interface
:Method Description Type getPreferenceFileName
Retrieves the name of the config file used by the UDL. Setup setApiParametersTemplate
Allows you to set up the plug-in parameter values. They can be modified from the UI. Setup setFilePath
Called inside the starting()
method to provide the plug-in with the full simulation path (including the simulation file name).Setup getGpuFileName
Initializes the GPU plug-in by accepting the file name without an extension. If empty, the model will not be supported on the GPU solver. Setup getGpuSourceSize
You must set the size of the char
array, which contains the CUDA source code. iflibraryProvidesGpuSource
is enabled.Setup getGpuSource
You must set the char
array with the CUDA source code, iflibraryProvidesGpuSource
is enabled.Setup setup
Initializes the plug-in by reading any config files, opening temporary files, generating data structures, or other setup tasks. Setup starting
Called once at the start of a simulation to indicate that processing is about to begin and the model should allocate any temporary storage and retrieve any required file/API/socket
handles.Simulation stopping
Called once at the end of a simulation to indicate that processing is complete and the model should free any temporary storage and close/release file/api/socket
handles.Simulation externalForce
Used to add particle body forces (such as electromagnetic or drag forces) to particles. This function is called every single time step for every single particle. Simulation configForTimeStep
Called during processing, at the start of each Time Step. Not used for CUDA solvers, but must be implemented in the CUDA file. Simulation getNumberOfRequiredProperties
Returns the number of custom properties this UDL wants to register with the system. Setup getDetailsForProperty
Retrieves details for a given property. These properties will then be registered with the system if they do not conflict with the existing properties. Setup getParticleParameterData
Retrieves particle parameter data in buffer format. Setup getSimulationParameterData
Retrieves simulation parameter data in buffer format. Setup setApiManager
Called once during the loading of the API to set the apiManager
.Setup processParticleOfInterest
Processes particles that were marked for additional processing in the externalForce
call. Particle modifications are not allowed.Simulation Note: The methods of type 'Setup' are called once at the start of the simulation, whereas, those of type 'Simulation' are called during the simulation. For more information about how the methods are called, see the Help included in the EDEM installation folder.
