Contact Model User Defined Libraries
A Contact Model UDL consists of a shared library file and, optionally, a file containing preferences. Using the EDEM API, you can write and compile a custom Contact Model as a User Defined Library (UDL) written in C/C++.
- Create a directory in which you want to save the new Contact Model project.
Copy the following header files into the directory that you have created:
IPlug-inContactModel.hPlug-inContactModelCore.hIPlug-inContactModelV3_9_0.hPlug-inConstants.h
If required, copy the following optional header files:
CGenericFileReader.hHelpers.h
Create a new class (
CNewContactModel) derived from the Contact Model interface you want to use (for example,IPlug-inContactModelV3_9_0). -
Save the class declaration to a header file (for
example,
CNewContactModel.h).This file must consist of declarations of the methods in the selected interface, any extra methods required, and any variables. - Implement all the methods defined in your header file.
Save the file as a
.cppfile (for example,CNewContactModel.cpp). -
Create a new
.cppfile with implementations of the methods inPlug-inContactModelCore.h. For example, save this file asNewContactModel.cpp. -
Compile all your
srcfiles and link them together into.dll(Windows) or.so(Linux) library files. -
Ensure that the library and optional preferences file are saved in the Plug-in
folder (as specified in ), or in the same folder as
the
simulation_name.demfile (only applicable for EDEM versions 2025.1 and higher). - Start EDEM and then select the required Contact Model category from the Interaction dropdown list in the Physics section.
Click the + dropdown list and then select the new
Contact Model.
The following methods are available in the Contact Model interface
IPlug-inContactModelV3_9_0:Method Description Type getPreferenceFileNameRetrieves the name of the config file used by the UDL. Setup setApiParametersTemplateAllows you to set up the plug-in parameter values. They can be modified from the UI. Setup getModelTypeIndicates the model type of the plug-in. This is a mandatory method for every model. Setup getExecutionChainPositionIndicates the position in the Contact-Model chain for the plug-in to be executed. This is a mandatory method for every model. Setup setFilePathCalled inside the starting()method to provide the plug-in with the full simulation path (including the simulation file name).Setup getGpuFileNameInitializes the GPU plug-in by accepting the file name without an extension. If empty, the model will not be supported on the GPU solver. Setup getGpuSourceSizeYou must set the size of the chararray, which contains the CUDA source code, iflibraryProvidesGpuSourceis enabled.Setup getGpuSourceYou must set the chararray with the CUDA source code, iflibraryProvidesGpuSourceis enabled.Setup setupInitializes the plug-in by reading any config files, opening temporary files, generating data structures, or other setup tasks. Setup startingCalled once at the start of a simulation to indicate that processing is about to begin and the model should allocate any temporary storage and retrieve any required file/API/sockethandles.Simulation stoppingCalled once at the end of a simulation to indicate that processing is complete and the model should free any temporary storage and close/release file/api/sockethandles.Simulation calculateForceThis function is called when two elements are in contact with each other. These elements can either be two spheres, or a sphere and a Geometry element. For two spheres, the function is called when their contact radii cross. For a sphere and a Geometry, the function is called when the contact radius of the sphere touches the Geometry. Element 1 is always a sphere, and element 2 can be either another sphere or a Geometry element. Simulation getNumberOfRequiredPropertiesReturns the number of custom properties this UDL wants to register with the system. Setup getDetailsForPropertyRetrieves details for a given property. These properties will then be registered with the system if they do not conflict with the existing properties. Setup configForTimeStepCalled during processing, at the start of each Time Step. Simulation This must be empty for CUDA solvers and implemented in the CUDA file instead. getParticleParameterDataRetrieves particle parameter data in buffer format. Setup getSimulationParameterDataRetrieves simulation parameter data in buffer format. Setup getPartPartContactParameterDataRetrieves Particle-Particle contact parameter data in buffer format. Setup getPartGeomContactParameterDataRetrieves Particle-Geometry contact parameter data in buffer format. Setup getDetailsForCounterPropertyFunctions are provided in IContactManagerApi_X_X(CPU) andCApiContact(CUDA) to add values to counter properties. This can be done by treating the data as a 1D histogram spanning the range[minVal,maxVal], or by specifying the bin index.This method allows you to use the counter properties as a histogram or a general array of counters.
Setup calculateTriangleDeformationCalculates deformation for triangular elements and returns parameters for the updated mesh element. Simulation getDeformationTransformSpaceDefines the Global or Local reference frame for triangle deformation. Simulation setApiManagerThis is called once during the loading of the API to set the apiManager.Setup Note: The methods of type 'Setup' are called once at the start of the simulation, whereas, those of type 'Simulation' are called during the simulation. For more information about how the methods are called, see the Help included in the EDEM installation folder..
