User Defined Library Contact Model
A User Defined Library (UDL) is a custom library that you can write to define your own Physics models.
The following high-level sequence of the steps to write and use a UDL contact model are as follows:
The programmer typically adapts an existing contact model source file (available from the Altair Community) using a development environment or editor. Once compiled, the new contact model is loaded into EDEM for use in simulations.
Note: The same steps apply to both Particle Body Force and Particle Factory UDLs.
