Switch to an Active Remote Desktops
Switch from one active remote desktops to another.
                Click the Desktops tab located in the upper left-hand of
                    the page.
                Remote Desktops list is displayed.
Figure 1. Remote Desktops List
                Click Connect.
Figure 2. Remote Desktops Connect
Note: By default, the timeout interval when a remote desktops is opened is set to unlimited. The default configured timeout value is set to 120 minutes (2 hours) for a remote desktops and it is displayed in the remote desktops tile. Time out will start when the remote desktops is closed, and the remaining time is displayed in the remote desktops tile.A remote desktops of the interactive application is opened in a new window.Figure 3. Opened Remote Desktops
                Click
 to view the remote desktops
                    options.
                Figure 4. Remote Desktops Control Options
The remote desktops control options are displayed.Figure 5. Remote Desktops Control Options
                 Click
 to view and switch to other active remote desktops.
                The remote desktops list is displayed.Figure 6. Active Remote Desktops List
                    Choose one of the following options:
- Double-click an application.
 - Select an application from the remote desktops list and click OK.
Note: The list will display the current remote desktops as well but you cannot select it.The selected application will be opened in the window.
