Stress Test
After saving the part, by clicking the Stress Test button, users can perform a stress test by varying input parameters.
A dedicated panel displaying only input parameters will appear, allowing users to modify their values and observe the part's behavior.
This stress step is crucial for parametric studies, enabling users to understand the permissible value ranges of each input parameter and their impact on the design.
If a parameter value results in an invalid part configuration (e.g., changes in the number of bodies or line intersections), a warning message is displayed. The sketch is regenerated, but several validation criteria may become invalid.
To restore the last saved configuration, users can click the Recover Part button.
